Re: How big of a motor can I put on my '93 Nitro 17' boat?
I have actually done something similar so I'll share my results.
I put a 1985 120hp johnson on my skeeter sd80 bass boat. The boat is 15.5' long. Max HP on the tag is 80, I think. The biggest different for me was going from a little 50hp yamaha that weighted about 200lbs to the v4 that weighs a little over 300lbs.
Coming off the throttle too fast can splash water over the back but hardly any actually makes it into the rear storage compartments, it just runs back off. With that being said, it sits no lower in the back than all the bass boats you see with the big engines on them. No water comes in unless I'm rocking in large swells in the middle of a lake or something. The other thing it does is porpoises pretty bad at slower speeds, even if I'm trimmed down. When I running faster than 35 or so it's smooth and the engine barely works. I think the biggest concern would be the added weight to your transom. Be sure it's not rotten. Oh, I have pretty bad torque steer too.
My boat handles great at WOT with no chine walking at all. Oddly enough, it handles better than my uncle's 21ft triton with a 225hp, at the same speeds. With my old paddle wheel ray marine fish finder, the boat used to top out at 38mph with the 50hp yammie, now it will do 68mph with the 120. I had it going faster once but the wheel came out of the water so I shut it down. I haven't verified with GPS yet but I have an app on my phone to do that now. I'm usually fishing out of my other boat now days.
Is the force 90 a v4? It sounds like what you're wanting to do won't change your weight nearly as much (if you keep to 2 stroke) so I'd change it if it were me.
