Glad I found this website. Learned a lot in last couple days already. I bought a 1986 skeeter F-80 boat that was in great shape but the 75 hp Mercury 3cyl motor needed some work. The lower unit gears were trashed so I bought a rebuilt lower unit and thought everything installed smooth but when I fire the engine up the propeller turns also. When its not running I tried to turn the propeller and it will turn clockwise but make a clicking sound. Won't turn to the left at all. Shouldn't the propeller be free to turn both ways? Should I remove the lower unit again and try to line the shaft up differently? Any help on this would be greatly appreciated.
2nd - My power trim doesn't work. When I hit the button it makes noise like the motor is running fine but it won't go up or down. Anyone got a couple of steps I can check into to? I have just ordered a Mercury manual for it but you guys expertise would be helpful too! Thanks!
