corona2627
- Jun 19, 2010
- 41
Still trying to get my Mercruiser 165 Inline 6 started, have put new plugs, plug wires, distbuter cap, rotor, condenser, rewired and put in new ignition switch, all new fuel lines, new Racor Fuel Water Separator and new solenoid switch. Bought a new battery last year, which I stored out of boat in warm dry place. Keep running the battery down trying to start the engine. She will try to start, but found out she is not getting gas. I did prime the Racor. I do have an old mechanical fuel pump. I did not see gas coming out of the carb so I took the fuel line off from the pump and no fuel in the line. While turning the engine, no gas coming out of the fuel pump. So I just need to have some confirmation from someone smarter than I am to tell me that I need a new fuel pump, or could something else be the problem, I do have about 3 gallons of new clean gas in the tank, is that enough gas after all new lines and water separator installed? Also, should the battery run down so quickly after about 6 to 8 good cranks of the engine?
Thanks,
Dianne
Thanks,
Dianne
