Hi guys,
I'm looking for some advice.
I own a few older Johnson outboards and have been doing some basic maintenance on them. I don't have much experience with motor repair and have basically been doing some greasing and other minor repairs on them.
I am having some issues with a 1979 15 HP motor I own. It is a model 15R79E and it sat around for a year after I had a starting mechanism failure. I fixed the issue (spring) and just recently put it back in use.
The problem I am having is that when it runs it won't stay a high speed for a long duration of time without sputtering to a slow (almost idle) speed. If I bring it back to idle it stays running but then has issues getting back up to high speed.
After reading some of the forums I troubleshot to fuel delivery issues. I have replaced the entire hose (new hose, pump bulb and clips) to no avail.
My question is: Would you think I have a fuel pump issue or a carburetor issue?
It does run at a trolling speed for hours ( I just went fishing all afternoon) and will run at high speed continuously sometimes without issues. It just won't go at top speed without doing the sputtering thing and going through a hesitation interval.
Any help would be appreciated as I am hesitant to just go out and buy a new fuel pump or carburetor rebuild kit.
Thanks
Thanks
