Silverbullet555
- Mar 13, 2011
- 621
I am working on installing a swim platform. While doing this work I decided to reseal the other screw holes in the transom and the garboard plud. Pulled out the screws holding the speedo tube and the temp gauge and all the wire clips. Imagine my surprise when one of the holes wept water. They were sealed with silicone which is beyond me as to why Cobalt would use silicone to seal this stuff.
Anyway, I drilled the hole out larger and thh fiberglass is dry, but when I get to the back of the hole, where it breaks through into the bilge, I get water. This hull is not fully lined as far as I know so I'm not sure where water is staying.
I drilled all the other holes larger, 1 slightly above, 1 slightly below and toward the keel and some others up higher. None of the others have water.
In order for me to grind from the inside I would have to pull the motor and if I do that, this is going to get much more involved because I will be doing a lot while the motor is out.
The brochure says cobalt was using a synthetic transoms in 2002 and this hole is not in the transom, but rather in the spot between where the transom ends and the bottom of the boat is.
I have a call into Cobalt, but the nearest dealer is about 130 miles away. I am waiting for them to call me back.
In the meantime, what are the thoughts from the experts on here.
