New to forum. Very new to boat repair. I found a 1977 Orion Tri-hull with the 1961 Evinrude Starflite 3, 75 HP with the unicharger. Model 50926 Serial 02208 The unicharger is wired to the ignition switch and the motor starts and runs. But, the accessories on the dash are not wired. Need to wire fuel gauge, etc. There are a positive and negative terminals at the bottom of the unicharger box and it is marked "Accessory Terminals". Stupid as it may sound, I am wanting to know if I simply hook positive/negative from the accessories to these terminals?
Thank you, sandbob
Thank you, sandbob
