I'm inspecting things under the cowl this weekend and I notice the throttle valves are not fully opening when the throttle is pushed to wide open. I have a manual and everything is set to spec on the carb linkage and cam follower, however, the butterflies are not fully opening at full throttle. I'd say they're about 2/3 open and definitely not flat.
I'm wondering if the cable is stretched or flexed since it is pretty old or what would cause the valves to not fully open anymore? The boat has been in storage for quite a while and the settings on the linkages and everything are still factory settings. The engine is in great condition. I'm afraid to adjust anything because it all looks correct per manaual. Just not opening all the way? I did notice the plastic casing on the end of the throttle cable has a little slop in it, but I think this is normal on other cables I've looked at?
Here's a video of it idling on the muffs yesterday.
http://www.youtube.com/watch?v=1ethbRLfheM (sorry for the ****-eyed video, still getting used to phone)
Any help?
Any help?
