I have a 1748 Tracker Grizzly with a 25hp 4 stroke Mercury Bigfoot engine. Now I'm aware of the gear ratio in the motor and it's original purpose to push bigger boats/heavier loads rather than what I have. That being said, I have tested the prop on it now which is the factory 10.88X11. The results were ok getting the boat going about 23mph fully loaded with 2 people on board. Here's the problem, I'm only clocking about 3000 RPM on my tach, so I'm not getting the engine's full potential. Now I'm using a Tiny Tach and verified it on other motors to make sure it's correct, and it is. So question is whats my best way to get to my optimal range of between 5500-6000 RPM? Should I decrease my diameter and pitch? Any help would be great, thanks guys.
