Hi everyone, I hope someone can help I have a 115hp Johnson Fast strike J115GLECM 1998.
I have 2 problems with this motor. When running at 20MPH I feel what seems as though the engine is missing. I checked the inline filter and it is fine no debree. I checked the site glass and saw air bubbles and when I see a bubble this is when the engine sputters. So I replaced the main fuel filer and the pump ball and the hose going from the pump ball to the site glass. No more air bubbles and the problem with the engine missing seems to be fixed.
When I run the motor in the driveway it idles fine and has no issues. When I take it to the lake after running it for 3-4 min or so at about 20MPH and then go to an idle speed while still in gear it will idle for about 1 min and then die out. It is then hard to start. The pump ball still has gas in it and I checked for air leaks via the site glass. No air leaks. Then I ran the boat again at a constant 20MPH and I noticed that the speed would change a little up and down but I am not touching the throttle.
Any ideas?
Is there a way to check the fuel pump?
Any ideas?
