I have replaced the water pump and made sure there are no obstructions for the inlet. While idling the motor overheat alarm will come on. When I put the motor in gear and accelerate the alarm goes off. The same thing happens when ears are on the engine and it is idling. Rev the engine up and it cools properly. The thermostat is not sticking, it has been checked. It does the same thing with the thermostat out. When idling, the **** stream is not as forceful as when it is revved up. Any suggestions as to what to check next?
Thanks
czwally
Thanks
czwally
