I am having issues with a 2004, 150HP Johnson outboard, 2 cycle. It will idle fine but as soon as I put it into gear and try to give it gas it will die. I can flutter the throttle in neutral it will sometimes go. I checked all the fuel lines and the pickup in the tank and all seam to be fine. I replaced the ball, it sometimes seems soft. It seems to be running rich.
Could it be the ignition module? Need to rebuild the carbs?
Any help would be appreciated.
Thanks,
Jim
Thanks,
Jim
