Electrical Diagrams for a 1979 Skeeter Wrangler 120
tje6741
I bought this boat used and none of the gages and switches work its my first boat and Im a navus at this stuff so Id really appreaciate any help I can get Thanks
Star
Re: Electrical Diagrams for a 1979 Skeeter Wrangler 120
I requested info from Skeeter and they were very helpful try them!
Silvertip
you really don't need a wiring diagram but if you do get one, you will probably see a pair of red and black (#8 or 10 gauge) wires running from the battery to the fuse panel at the helm. There is typically a fuse in the red wire close to the battery. Check it. That pair of wires feeds the fuse panel. Circuits branch out from there to the various switches. Since none of the accessories work, check for voltage at the fuse panel and work backwards to the battery. That main feed is the problem. The gauges are powered from the ignition switch ("A" or accessory terminal) when the key is on. If none of them work, then that says either +12v or ground is missing at the first gauge in the string. The ground. +12 volt, and internal light wires are daisy chained from the first gauge in the string to the others. Fix the first one and the rest will likely come to life. Knowing how to use a test light or voltmeter is essential for electrical work. I should add that since this is an older boat, it is highly possible multiple owners have mucked with the wiring so even the factory diagram may be of little help short or a total rewire. Even then, 1970's wiring concepts are drastically different than todays. Check the "Generic Boat Diagrams" in the stickies at the top of this forum.
rgw004
I also bought an old skeeter (1984 R-90 Strada) and when I inquired, they were completely unhelpful.
I would love if you send the diagram my way, or tell me how you were able to get something out of them.
Here is the copy of my exchange with them:
Skeeter: Dear Sir Thank you for contacting the Skeeter factory. I am happy to help. Please go to the Skeeter website www.skeeterboats.com and select "my boat." There you will find a downloadable owner's manual. Thank you in advance.
Me: Okay. This appears to be a generic manual of sorts. Would I be able to see the original plans or model relevant information? I am attempting to do a restoration and any model specific information would be helpful.
Skeeter: We do not have any other information that goes back to 1984. I am sorry we cannot help.
Me:There is no product specific data at all?
Skeeter: (No response.)
