j_k_bisson
- Oct 6, 2010
- 1,082
I have a 1987 225 evinrude outboard and I am trouble shooting various small issues that have come up since the intallation. I have rebuilt eveything, and recently installed it on my boat. I have also spliced in the evinrude wiring harness into the force harness that was in the boat.
The issue I am having is where I activate the trim switch on the dash "up" it works perfect. When I push down it works, but does not shut off. I am just sitting here thinking that the relay might be sticking. The switch is a mechanical momentary "up-on and down-on". So it is disenguaging. No power is flowing to and from the switch when I test. Could the relay be bad?
DO these relay some times stick when activated?
I am going to swap (Up for Down) the relays tonight and see if it happens in the reverse situation and sticks.
