The manual states to apply Mercury Perfect Seal to the small hole gasket on the water pump housing. Do you use it on both the top and bottom of the gasket or just one side? and is the permatex aviation gasket maker sufficient? This is on the alpha 1 gen 2 drive.
Thanks for the help.
