Couple weeks back, I rebuilt my carbs, replaced my fuel lines, tore apart my trim and put it back together. The last thing I was told was bad was my kill switch, which I also replaced.
After getting it all back together, I started it up, it ran absolutely perfect, until I went to shut it off. I turned the key to the off position, it kept running, I pulled the kill lanyard, kept running, finally in a bit of frustration, I pulled the ignition switch and started disconnecting wires until it finally shut off. Problem is now I dont know how to wire it back up. Does anyone know how to properly wire up the ignition switch?
Its a 1989 ranger boat with a 150stlcem. It has a hidden remote, with a gunwall mounted killswitch and the idnition switch is seperately on the instrument panel. I am looking for some sort of wiring diagram, or some clue as to hook it back up.
