Re: How do these u-joints look to you?
Sourced the gimbal bearing and the driveshaft bellows locally. I probably paid more than I should have but I was anxious to get started. I bought a set of "Rear Axle Bearing Pullers" from Harborfreight and
http://www.harborfreight.com/rear-axle-bearing-puller-set-66380.html and rented a slide hammer from Autozone.
The gimbal bearing popped right out with just a few gentle taps with the slide hammer. I was relieved after reading
http://forums.iboats.com/showthread.php?t=364003 this post about replacing gimbal bearings. If you are thinking about doing this yourself, reading this post first will make it a lot easier.
This is a picture of the old and new bearings with the slide hammer and the bearing puller:
Getting the new one in was a little tougher. I fabricated a driver from a 3" diameter piece of PVC pipe and carefully seated the bearing and then drove it all the way in with a series whacks with a hammer.
Next was the drive shaft bellows. Thanks again to Don S and his excellent advice about disconnecting the water line and the exhaust bellows and shoving the new one in from the bottom. Saved me a ton hassle.
Here it is assembled with the new bearing and bellows:
Notice the fresh grease oozing from the bearing. Make sure you test that you have it lined up with the grease extension tube from the grease fitting on the starboard side of the housing before you slap it all back together.
