I just purchased my first boat (total noob)... a 14' Jon boat with a 1967 Johnson 9.5hp outboard which looks restored, it's very clean and appears to have grease in all the right spots. The engine starts on first pull (even in gear... to my dismay). After taking it out on a lake for a day I noticed a slight oil leak in lower unit.
Upon careful inspection I see there is a small hole (approx 3/32") in the bottom of the fin directly above the prop. It looks like a factory hole. I changed the lower unit oil and found water in the oil. The oil and water were leaking out of the hole but only a small amount... it's not a mass leak. Is that hole suppose to be there?
I changed the oil and tried another trip to the lake. Again engine ran great but when I got home I see the same result with water/oil and it?s leaking out of this hole just the same as before. I'm worried that the water is getting into the L/U Oil through the hole. I bought a Service manual and none of the graphics show the bottom of the fin at all and none of the breakout drawings ever reference the hole.
Also? my Engine Model Number is 9722M, however, any reference I can find is always 9722B? Does anybody know why there are no M references anywhere? Does this matter? Is the M for Mechanical Shift? The engine has forward, neutral and reverse via flipping a lever up and down. Thanks in advance for any help you can provide.
