when i open twist to wot i still can open butterfly more at least 1/4 in....not running when i do this.also on the armature control the pin that goes in bottom broke on one side..will that effect anything..motor runs good just does seem to get to wot..coils plugs water pump carb redone..should i do the condensers and points as well? cam follower has groove in it..
