1974 Mercruiser 140 clicking in lower unit
beericks
I got my boat running the other day. It was hooked up to an earmuff and idling in neutral and I heard a clicking noise in the lower unit. As the RPM increase so does the clicking, but when I placed it in forward or reverse the clicking stopped. Is this normal?
Re: 1974 Mercruiser 140 clicking in lower unit
Nope,... Sounds like the shift cable is outa adjustment, 'n the dogs are dragging against each other...
Don S
No, itr's not normal. Sounds like the shift cable is a little out of adjustment and allowing the shift dogs to just barely touch causing the clicking.
