Re: Holley Carb question
I have a Holley 2bbl. on my 302. It is electric choke.
When I turn the key to the on position, the choke open the carb all the way and it is a ***** to get it started, unless we hold it closed and gradually open it up after it warms up. I actually have to identical carbs and they both do the same thing. We have adjust the side of the choke to make it lean or rich and nothing.
Any suggestion?
Thanks.
The way the electric chokes works is, when you turn the key to the "on" or "run" position, current starts to flow through a coiled up, bi-metallic spring. When the spring is cold, the choke in in the closed position, restricting air flow and richening up the air fuel mixture. The longer the key is on and current is flowing, the hotter the spring gets. The spring start to uncoil and that moves the choke to to the open position with unrestricted airflow.
If you turn your key on at the top of the ramp, you could be heating up the spring without running the motor, and then when you are ready to start the motor the choke has already done it's thing and you are in the open position.
The electric choke is also adjustable, by physically turning the spring housing. If it is mis-adjusted, the spring will never be able to close the choke and you would again be always in the open position, or it would open really fast. There are marks in the spring housing to help you adjust it, but moving the housing so the choke is fully closed ( but only just barely) when it is cold is how you pick a starting point and fiddle with it from there.
Do either of these scenarios sound like what happens to you?
You can also (I have been told), burn up your choke spring by leaving the key on when the motor isn't running, something about no airflow to cool it (a bleed hole that pulls air through when the motor runs?), but I have left mine on accidentally plenty of times for hours and mine still works fine. I try not to do it though. I imagine that a burned up choke spring would not work at all, which is the opposite of your problem though.
