Throttle sensor assembly
jvstream
What function does the throttle sensor assembly that is mounted to the middle carburetor on a suzuki dt85? Does this affect the fuel pump? It has three wires coming out of it (one is a ground)
romanakr
Re: Throttle sensor assembly
Can someone tell me how to test the throttle sensor assembly on my dt65 suzuki?
CobraCommander
It controls the timing as you open the throttle. You'll need a multi meter to test it. Buy the manual for that engine and it will take you step by step on how to test it and what the ohms reading should be. I have a dt200 and the ohm reading is between 225 and 275. Yours might be different.
