Re: 4 HP Mercury Engine Stopped and will not start
sounds like a timing issue, bad gas, point gap, plug gap, coil wire, coil, many things can do this. start with fresh fuel being the motor is fairly new i wouldn,t think points if it even has any i don,t know but be sure to check the plug wire and coil wire are correctly inserted and have no cuts on the wire itself I,m just trying to give basic info to try to help
