cant seem to get any info from yamaha,,,,can anyone help
Ive been trying to diag problems with this z300 04 model ,, she runs up to 3200 rpm easy, but wont run out further fells like shes running low on fuel preessure
measured pressure at the vst while in gear holds about 25 psi at 3200
and the high preesure pump reads 850-900 psi then the engine starts falling back on power. is that psi to low for higher speeds
