sundburg61
- Apr 14, 2011
- 1
Any tricks to installig exhust billows,the transom side was sort of easy, the outdrive side seems impossible!!!
Figured out away by chance. Went to Harbor frieght and braught a 16" long pair of needle nose pliers with a 90 degree angle on the end. The tip is blunt so as to NOT put a hole in the new bellows. With the outdrive removed and the bell housing in the the down position I slipped the pliers past the vertical shift shaft and GENTLY worked the end of the bellows over the exhaust opening from the inside(with the plirers closed, the 90 deg. angle is the trick.). With the bell housing down your not trying to streach the bellows and I did it in about a 1/2 hour. I hope this helps anyone else who has to preform this fun task.
