84 johnson115hp
dhansell
Just wanted to know if anyone had any idea about how fast my 84 115hp johnson should push my 84 glastron carlson cvx 16. I am thinking something is wrong with the motor because i can only get about 35 mph. But i have seen them with 90hp and do 45+.
thanks
Dale
ezmobee
Re: 84 johnson115hp
On a 16' I would think 40+. Is your hull waterlogged by chance?
Your WOT RPMs will be crucial to know in troubleshooting this.
dhansell
Re: 84 johnson115hp
Im not sure if it is water logged are not but it was sitting in the rain for a little.. RPM was about 42
SparkieBoat
Re: 84 johnson115hp
you need to weigh your boat, also a rough bottom can make a real difference. that is way to low RPMs something is not right...
D
DJ
Guest
Re: 84 johnson115hp
4200 RPM shows:
1. A severely heavy boat.
2. Mis propped. Should turn at least 5500.
3. Sick engine, not running on all four. Compression test is in order-#1.
dhansell
Re: 84 johnson115hp
Ok i am going to get do the compression test do you know were about it should be.
