Cricket Too
- May 14, 2003
- 1,732
I got a new powerhead in October for my '97 Johnson 115. I got it from a pretty reputable OMC rebuilder in FL.
It was installed up here in NY, by a very reputable OMC shop. The powerhead has about 5 hours on it and it's being run at 25:1 and I've been following break in procedures. Engine runs great.
Uncovered the boat for Spring, took the engine cover off to run it, and I see what looks to be salt crystals at the top of both head gaskets, and both salt crystals and water sitting on top of the heads, both sides. The engine is flushed after every use, and was obviously run on muffs out of the water when fogged in December.
I have heard that sometimes head gaskets can make a powdery substance that looks like salt, but this substance it too crystal like, doesn't look like powder, looks like salt crystals. Also you can see in the below pics that where it has been sitting all winter the paint is gone now and there is slight corrosion.
Is it possible for these HG's to be leaking already, and would they leak like this? Is this a defect? Is this something else? I plan on taking this back to the shop that installed the powerhead but I wanted to post on here to satisfy my own curiosity and get an impartial answer from someone not responsible for the work.
Please take a look and let me know what you think. Port head is kind of hard to see or get a good picture of, 3rd pic down. Thanks.
