fishfreak1985
- Feb 14, 2011
- 5
I got a late 90's model 15 hp gamefisher that runs great once it starts.The motor was rebuilt by sears and was not used after till now it sat for about 10 years. I am having two problems...1st being the primer bulb is not working i have to pull the fuel line off the back of the bulb and blow in it to prime it...i can not find a primer bulb to it can i use one off another motor?? 2nd is after we have been running about half throttle for about ten min it wants to spit and sputter till I open it up then it is fine for 10 to 15 min more then it does it again...I have cleaned the carb and put new plugs in???....thanks in advance for all your help
