I have my drive off and I started to drain it with it on a stand. When I pulled the drain plug and the vent plug, it drained very very slow. It didnt change when I tried pushing the ball valve either. I was wondering if anyone could tell me what all is lubricated by the gear lube? When I pulled the upper and lower apart, I have some lube in the upper spline area and housing where the lower drive shaft fits into. I did not have any leaks prior to taking it apart. Is there gear lube where the drive shaft on the lower housing fits into?
Thanks for any help
Thanks for any help
