Replacing Volvo 5.0 GL riser gaskets
SeabrookStu
I am replacing the gaskets between the risers and manifolds on a 1999 Volvo 5.0 GL PEFS. I have the new OEM Volvo gaskets but they don't look uniform on each side. The metal gasket looks like it has been stamped and there is a raised surface, but the two surfaces look different on each side. Which side of the gasket should go up? Does it matter? I have read other posts and am aware there is a new Volvo service bulletin that recommends a copper based gasket sealant, but I'm still not sure which way to mount the gaskets.
