stephentungate
- Mar 31, 2009
- 12
I bought a nice boat with a 65hp merc on it. The guy told me it ran last year but for some reason couldn't get it to open up on the water. It would only run at half throttle. I bought to boat and it doesn't get fire to the plugs. I contacted someone who works on boats and they told me the best thing to do is throw it in a lake. It's a good looking motor and I really want to learn how to fix it myself for the experience. I don't have alot of money to spend but if someone could answer a few questions for me it would get me on the right track. First of all I know nothing about outboard boat motors other then what i've learned in the last 2 weeks tinkering with that one and reading posts on here. I am almost positive the motor has a new stator because i found the old one in the livewell. I tested the wires going to the motor from the control box and they test at 12v except for the one that goes to the selinoid it tested about 4.3v. One question I have is the wire that is connected to the coil, (where the magneto, trigger, all taht stuff is) has not voltage to it at all. Does the power to that come from the stator or does it come from the battery when the key is turned over. I'll post some pictures of what i'm talking about. I took off the distrubitor and the coil and the distributor was cracked and busted on one side. My buddy cleaned the rotor button and put it back on but still no fire. I tested the plug wires with voltimeter and th plugs where getting some voltage like 0.04 but nothing significiant. I can get parts from oldmercs.com but I think its strange the wire going to the coil isn't getting fire at all even when turned over. Thank you..I appreciate any help. I can't afford a repair tech.
It's a merc 650 4cyl serial number 2018405 with 4D magneto KD-4 Kiekhaefer
