This motor is marked 4.5 but as i look up serial numbers for the year it was mfg. It does not jive ! The tag # is 3399968. I have replaced the point insulator, no help ! The points look good and make a test light bright ! It has a red ignition coil and the stator has 2 coils with a large condenser . I got a lot of help on a 7,5 merc from you guys (those dammed point insulators) what should i look for next ??
Gramps
Gramps
