pine island fred
- Dec 20, 2002
- 1,144
Have never worked on a pontoon boat before. Neighbor woman has a SWEETWATER about 20 ft. she says has water in the pontoons. My question is what is inside those things? Is there any flotation foam injected in them. Are there seperate compartments, each one water tight or is it it one big tube?
Looked at it today, is on a trailer, could not find any drain plugs. Along the top are 3 spaced 1/2 in. pipe plugs, under the deck, hard to get to. Would they be for seperate compartments ? My plan is to take a hole saw and cut a hole way above the water line. Stick a hose in there and fill it with water. Once I find the leak, I can pump the water out. Am I thinking correctly? Would a 2 in. hole degrade the integrity of the pontoon, like denting a can?
Is a salt water boat, normally left in the water year round. regards FRED
