reef donkey
- Mar 17, 2011
- 8
Hi,
I have a 1997 evinrude ocean pro 175hp. If I prime the bubble and run the motor for
ten or fifteen minutes, then turn off the motor, unscrew the water seperator and it is half full of fuel ,is this a fuel pump problem? If the motor is in the water and I run it for thirty minutes and turn it off for about one hour or so, it start right up but when I give some throttle it dies, but if I prime the bubble it will run, so with all of that could this be a weak fuel pump?
Thanks for the help
Thanks for the help
