Hello,
I am in the process of installing Structure Scan on my Lund Tyee. The dealer installed the HDS module before the sale. When I was under the console, I noticed that they used the inline 3 amp fuse and then ran that to the fuse block behind a 5 amp fuse.
This seems redundant. To clean it up while I am there, I would like to remove the inline 3 amp fuse and put the 3 amp in place of the 5 amp.
Does anyone see an issue with this? Common sense tells me to use the fuse block since that is what it is designed for.
Thanks,
Filo.
Thanks,
Filo.
