jasonachord
- Aug 27, 2009
- 37
So after two expensive and unexpected auto repair bills back to back this month I've decided to attempt to replace my Gimbal Bearing and drive bellows myself. It's that or no boating this year which I just cannot allow. After reading through many post and the Adults Only section here I believe I can handle this job myself.
I was able to successfully pull the outdrive this weekend with no problems following the directions in the Adults Only section. I don't remember reading that the speedometer tube would need to be disconnected in the outdrive removal directions but may have over looked it. After unhooking that the drive slid right out.
My ujoints looked good, were covered in grease with no signs of rust and both moved freely. The Gimbal Bearing however will not turn, it has seized up completely. The Bellows do not have any tears in them but all look dry and had water in them.
So now to order the hinge pin tool, alignment bar and transom seal kit before I can do much more.
My first question along the way is the buildup of metal flakes on my outdrive drain plug. Does this look normal or should I be concerned? The drive oil was replaced in August of 2009 when I had the impeller done so this collection of metal would be since that time. I will be draining and replacing this yearly as recommended going forward.
BTW, my out drive is a 1992 Alpha One Gen II
Thanks guys,
Thanks guys,
