charles 57
- Apr 11, 2011
- 4
Bought 1989 sportcraft hardtop rebuilt 305gm volvutdrive wont hold gear oil leaks quickly.Took out drive off & face plate to check out hasnot been used in 6 years No props on it either duel prop big splin & small counter rotating.Need to check out drive shaft turns prop shafts but no bolts in anode man said outdrive need work ? looks like some one took apart lower drive.Maybe I need to take it out to see if gears ok or whats wrong ? Any help would be great thank you.
