I have a head gasket leak on the top of cylinder number one. water is leaking.. Ive replaced the head gasket two times now.. first time i did not use any sealant. second time i put marking die on the head used a granite flat table with a sheet of emry cloth to check to see if head was warped it is not... so now im not sure what to do any suggestions...
