fishinandbeer
- Apr 11, 2011
- 29
Took the boat out to give the kids a boat ride and do a test run since it sat up all winter. Ran about 20 miles with no problems, except my Tac would quit working from time to time. On the way back the last mile to the boat ramp I opened it up for a little bit and when I came off plane the engine stated running rough. So I goosed it alittle and the engine went to a high idle then stalled. wouldn't start. Got it back home and put it in on the garden hose and fired it up and it went to high throttle. So I shut it off right away. Smelled burnt palstic so I removed the coweling and notived my timing, for lack of better word, lever was stuck in advanced position. pulled the cover to it off and and notice the retifier was sparking even with the ignigtion off. It had melted the back portion of the optical timing along with some wires and the rectifier was totally melted. So my question is. Should it still be getting power with the ignition off? What caused this? It's looking like it will be close to $600 in parts to fix it and I just don't want it to happen again.
