hello, i recently bought a 1998 regal 242 and took it out for a test drive.the engine is a new 5.7 upgrade on the 5.0 with a cobra sx outdrive i believ to be a 1.66 ratio.it runs great however it will only do about 10 mph.i can give it gas from 1500 rpms to 3000 and it just does not want to react other than rev up.i do not smell or see the black smoke as described in a coupler failer.and it is a new prop that does not appear to be spun out.i looked in between the engine and could not find any rubber pices of the coupler either.it makes a lot of water flop around but doesnt speed up.i measured the prop and it appears to be a 13" with 17 pitch.i can put it in gear without the engine running spin the prop and i will turn the engine but i would expect that as it will push the boat at low speed.can someone please tell me that all i need is ablankady blank prop with a pitch of something and this will fix it.if not what else is there to determin a coupler failing.many thanks in advance
