dheaton883
- Apr 10, 2011
- 10
I recently bought a 1970 starcraft V150 Deluxe and 1970 chrysler 70hp outboard setup for a really good price. I found water in the lower unit oil so i decided to tear into it and replace the seals. the seal that is under the water pump is whare the water is gettin in. Upon further inspection the bearing on the shaft is shot. The bearing looks like the wrong size because the bearing is pushing the snap ring up just far enough that it wont slide off. I have found the same bearing at the auto shop and it is too lose on the shaft. Does anyone know the what the right bearing is? Within the seal kit there are some parts that i dont know what they are to: a 3/4" x 3/4" square of 1/16" thick paper like substance, a thick 1/2" outer diameter black washer, and two yellow rubberish washers 5/16" outer diameter. If anyone can help me you would be a life saver. As i took it apart I was looking for these parts but havent been able to find them.
