1999 BIII. From the manual, it appears that I have the model with the later style cable. Page 4A-21. How the heck do I get the new bellows to slid over either cable end? First I'm pretty sure the cable needs to come out and then the bellows is slide onto the engine end of the cable, its entire length? Before being fed back through the gimbal housing. Both brass ends sure seem to large for the rubber bellow to fit over? Though the engine end of the cable brass seems a bit smaller. To remove the cable seems strange too. There's a clip in the gimbal housing that appear like it should be pushed into the bilge area from the outside of the boat, but I just can't tell. Then there's the cable wrapping, which I have no idea what it is even for. Is the wrap attached to the plastic fitting in the gimbal housing?
