OK, bit of a long story but here goes. My 1971 60hp gearbox self destructed last week and I found a 1970 60hp for sale at a reasonable price because it was a non-runner due to the ignition amplifyer being dead. As that part was OK on my engine I bought it and swapped the amplifyer over. The guy I bought it off had done an engine rebuild (new rings, gaskets, etc) and then the amplifyer went and he got chance of another engine cheap so he just put this one at the back of the garage until selling it to me. I was told it had been stood for about 3 years, and it was upright clamped to the end of a bench.
After swapping the amplifyer over and a few odds and ends that were needed I swapped the engine for the one on my boat. I was very pleased when it started up after only a few cranks over. It seemed to run well, so I took it out for a test. Here's where it all went wrong. I pulled away from the jetty fine, just on tickover, but wehen I pushed the throttle forward there was nothing. Then a sudden burts of power (that nearly had me crashing into the jetty!) and I quickly throttled back. But after that nothing on the throttle. It started and idles great, and I can get the revs up to about 2000 on the start throttle, but as soon as I push the throttle forward it just dies.
I'm thinking the idle jets are working fine, but the main jets are stuck/blocked from being stood for so long. Or the floats are stuck and the only fuel getting through is on the idle jet. I'm not very familier with these carbs, as you can probably tell. So my question to the experts is does this sound like what may be happening, and if so what is the easiest solution? If this is load of rubbish, could you tell me what the problem might be?
Thanks
Kevin
Thanks
Kevin
