I wanna say first off Hi all... I am new to the boards but I have read many of the posts before today. I have a problem I hope someone can help me with.... Ill try to be thorough but brief.
I wasnt sure if it was a spark or fuel reason i couldnt get the motor started... I had not been able to start the motor at all last year. This year I changed the fuel cleared most of the lines...and it started. I turned off the motor to change the impeller... nothing.. so I thought maybe its the spark. As I pulled the plugs to look for spark ... I cant see any. I came across the idea it might be the coil packs (from the forums)... so I took them to have them checked out. They passed and was told they should work. 2 days later I reinstalled the packs... the motor starts again.. LOL. I shut the motor down for the day .. come out the next day to do a compression check (forum idea ) when finished the motor restarted.
Finally today I went out and get the motor running.. this time I let it idle for like 20 mins... did a lil carb screw adjust... she purred like a kitten and pee'd cool water. After turning it off letting it cool ...I restarted it for a few mins... turned it to WOT for a few secs.... released the throttle ....then it went down to idle and died. I tried to resart and nothing. Why would this happen?
Should you be able to see the spark on the end the plug or is the spark jumping the gap barely visible? Seems like I have no/weak spark. and i was hoping to take the boys fishing this summer. Sorry for the long story.... Any help would be much appreciated.. thanks.
By the way .. I rented an auto compression analog tester. I got between 45-51 on the 3 cyls. with throttle open and all plugs out... do those numbers seem low?
