Ok.....I installed the points, condensor and a impeller. I changed the oil in the lower unit and it was slightly milky. I went ahead and put new oil back in it and ran it in a barrrel for 3-4 minites and adjusted the carb. I did another check on the oil and it is very milky looking now. Could it be the driveshaft seal leaking? Its a 1968, 33ho Johnson and it has a split gearcase.
