TravelerIII
- May 25, 2009
- 2
I have a 1982 Chris Craft 264 and am having trouble identifiying the engine model number.
I was able to locate the block number on the port side under the cylinder head
Block# VO712CHC
181337029
The Hull# is CCBAR154M82I
I was told the engine was replaced.
On another post the response was on welch plugs on the power head. I am not quite sure where these are located. Also the manual also claims that another number could be stamped on the port rear side where the engine attaches to the bell housing or a plate or sticker on the transom bracket.
The valve cover has OMC 260, but where the manual shows the
sticker ID tag is not there (rusted and gone)I was able to locate the block number on the port side under the cylinder head
Block# VO712CHC
181337029
