1985 70 evinrude vs. 1984 115
LDRunner
I currently have an "86 16" Grumman bow rider runabout with the 115. Boat is fast, but sucks gas. Boat is only really rated for 70 HP. The 85 is in great shape. How much would changing back to the 70 affect speed and power? Thanks for any advice.
SparkieBoat
Re: 1985 70 evinrude vs. 1984 115
save some on gas but lose a lot of power. If your 115 is sucking gas that bad it may need to be repaired. If you run the 115 at 3/4 throttle instead of wide open it should get about the same as a 70. if the 115 is too heavy for the boat it could be pushing the hull too far down in the water, making it struggle to get on a plane, but without driving the boat i am just guessing..
