4.3L Mercruiser
Corriente Kid
I just purchased a 1999 runabout with a 1999 4.3L mercruiser. The seller told me that he installed a fuel pressure regulator because the carb was getting too much fuel. I haven't check the fuel pump to ensure that the correct pump for this model is installed yet but I was wondering if someone can tell me what the proper fuel PSI is for this particular engine? Thanks.
Re: 4.3L Mercruiser
Ayuh,... If the motor is Carbed, 'n has the right fuelpump, No regulator is needed...
4 to 6psi...
