bowhunter71
- Apr 17, 2006
- 39
I have a heavy aluminum 20' Polar Kraft mod V with a 1995 johnson 130hp.The 130 has a different lower on it with a different gear ratio.It is supposed to be a 12:27 and it is a 14:26.The 130 had a 17 pitch SS prop on it but I could only get 4800 rpms out of it so I went to a 15 pitch prop not much difference so I got a 14 pitch SS prop and I still can't get past 5000 rpm's.I went out today and got 38 mph at 4800 rpm with the 17.I got 36 mph at 5000 rpm with the 14. I think there should be a bigger change in rpm between the 2 props.I think I should be able to run a higher pitch prop.I read somewhere that a 14 pitch prop would be for a large cabin cruiser.I have a used gear set to make it stock but I was told there was only 21% between the 2 gear ratios.Not sure if it would be worth the money to have the gear set changed.Maybe it is my powerhead.I am going to take it in to get a link and sync.I would like to get the rpms in the high 5k range.Any ideas?
Thanks in advance,Jeff
