krs60
- Aug 30, 2009
- 131
I need some help with the pictured control. What do the levers control? I assume the bigger lever controls forward, nuetral, and reverse but what does the small lever control? I recently got the boat and am just now going through it. I found the bigger lever only moves from the up position to the rear position, then it can be moved back to the up position but will not move forward. I'm also getting power to the solenoid but no power when turning the key so i think i may have ignition cylinder problems. Motor turns over when i jump the solenoid with a screwdriver. Any info on control operation or other troubleshooting appreciated!
Bigger lever back...
Bigger lever as far forward as it will go...
Smaller lever, what does this do???
