This parts listing is for your engine and if you look under Gear Housing Assembly Complete, you will see that the lower shift rod is available as item 39:
They are not too hard to find, depends where you are we could direct you to someone who has one. To change it you do have to remove the powerhead if it is the upper shift rod, that is not as difficult as it sounds.
